VC starter drive question
Mike in UP of M
05-26-2005 19:53:45
Had a problem with the starter drive on my VC. The starter would turn but it would not engage the flywheel. Pulled the starter off and found the starter gear was stuck. I broke the gear loose and removed some burrs that it was hanging up on. It now works good. And the helical gear that drives the starter gear appears to be in good condition. My question is, should there be some kind lubricant used on the helical gear?
Thank you, Mike
jstpa
05-26-2005 20:11:29
 Re: VC starter drive question in reply to Mike in UP of MI, 05-26-2005 19:53:45
Mike, you dont really want to lube that drive with oil or grease, it'll just collect clutch dust and such and gum up. That being said , I do put a spray graphite on them that dries instantly. hope this helps , jstpa
Mike in UP of MI
05-28-2005 19:24:18
 Re: VC starter drive question in reply to jstpa, 05-26-2005 20:11:29
Thanks, I'll give that a try.
