I broke it changing oil on 311b
HobbyFarmerInWI
05-26-2005 15:19:27
While changing the oil on the 1957 311b, I broke off the post (or whatever you call it) that slides into the oil filter.
1) How bad is this?
2) Will JB Weld hold it back in place?
3) Can I run the tractor without it, just putting the new oil filter back on?
I need to drill out quite a few post holes this weekend for the fences.
Thanks,
Bob
Joe (Wa)
05-26-2005 17:26:41
 Re: I broke it changing oil on 311b in reply to HobbyFarmerInWI, 05-26-2005 15:19:27
Did it break off or just pull it out of the socket? It is just a by-pass filter so you can run w/o it until you have time to fix it right. You should blind off the filter at the block otherwise some of the oil pump output will just be dumping back into the sump. That means less oil up to the rocker arms, valve running gear, and your center and aft cam bearings.
To blind off cut a piece of sheet tin (tin can, roof flashing) same as the gasket but w/o the oil passage holes. Place the tin between the filter housing and the gasket and bolt it back on the block.
The original stem tube is just pressed into the socket of the filter housing. 1/4" soft drawn tubing about 4"L makes a good substitute. You will have to sand down the end for interference fit in the socket. Drill holes in the top close to that of your existing tube.
The hole sizes and placement is not critical, they are just used to direct the oil to the top of the filter media.
Joe
HobbyFarmerInWI
05-26-2005 20:26:25
 Re: I broke it changing oil on 311b in reply to Joe (Wa), 05-26-2005 17:26:41
Well, I thought I broke it, but after reading your message, I now see that it just pulled out. Can I just stick it back in?
Thank you VERY much for the great detailed answer to my problem!!!!! !!
Joe (Wa)
05-26-2005 20:49:51
 Re: I broke it changing oil on 311b in reply to HobbyFarmerInWI, 05-26-2005 20:26:25
It doesn't take much to keep it in there. You want an interference fit so the stem O.D. should be 0.003-0.004" larger then the socket.
You might try swaging the end with a pin punch or even a nail, careful not to split. Or you might try to build up the O.D. tinning it with solder (that will be your fix if it splits, you need not ask how I know that).
Joe
