David Brown 1200 clutch
Sean in Tn
05-25-2005 21:11:15
My DB 1200 has burned up two throwout bearings in the last few years. It's starting to rattle like it's going out again. I use this tractor to roll hay. Should I install a rebuilt clutch when I break it down this time? There's lots of wear on some of the clutch parts. Any ideas on where to find one other than the case dealer, they have been very good with parts, but high.
Sean
Sean in Tn
05-26-2005 20:54:26
 Re: David Brown 1200 clutch in reply to Sean in Tn, 05-25-2005 21:11:15
Took it apart today. Throwout bearing is shot again. I am glad david brown built them so the clutch can be worked on without spliting the tractor. I am not going to replace the clutch just put in a new bearing. And put her in neutral when I tie. Should last longer that way. I"m going to let it roll while I dump,that should help also
Mapleridge
05-26-2005 19:38:33
When you bale, do you put it in neutral while you tie? I have to force myself to do it, even though it takes longer.
Elmer
05-26-2005 03:04:33
A&I Industries can supply you a LUK clutch. DO NOT USE A HY-CAPACITY!!!!! ! If you can't locate an A&I agent let me know and i may be able to help you out.
