Case VAC
yeehaw
05-25-2005 12:19:10
Hey guys just picked up a 1946 case VAC. I was wondering what it would take to put a eagle hitch on. Would it just be finding the parts? or would it require switching to rearend? Or is there a way to make it 3 pt hitch? Just trying to get some idea, didn't buy it for this reason but if i could put one on it would be that much better for me...thanks and have a great afternoon all!!
fordfan
05-25-2005 22:23:56
 Re: Case VAC in reply to yeehaw, 05-25-2005 12:19:10
third party image
The hitch to which you refer I believe is called a stockton hitch due to it being made at the stockton plant. I am not at home right now to get you the address but someone on here ought to direct you to an imageevent website with several pictures of "homemade" three point hitches for VAC's. If you wnated a VAC with an eagle hitch, you should have bought one with one already. You would have to change the whole rear housing and get the low pressure pump that mounts on the motor. Come to think of it, everything is different. It's NOT worth trying to convert it. These stockton hitches are VERY hard to find. However, it is possible. E-mail me directly if you need more help or if nobody else gets back to you.
better picture
05-25-2005 22:25:45
 Re: Case VAC in reply to fordfan, 05-25-2005 22:23:56
third party image
better picture
fordfan
05-26-2005 11:43:14
 Re: Case VAC in reply to better picture, 05-25-2005 22:25:45
third party image
Here are the links that you should find useful.
Link
Link
http://photos.imageevent.com/skipjack/tractorinfo/tractors/icons/VAC%203-point0003.JPG
wheat straw
05-25-2005 20:30:08
Hey Yee Haw,
I've seen several af these hitches Amick is talking about. Saw two tractors sell with them and then saw one sell on E Bay taken off the tractor. There are some out there to be had but thyey are hard to come by. The whole tractor sold for 201.00 on E bay once and it had this hitch oon it. Some body got real lucky.
Wheat Straw
CK RICHARD
05-25-2005 19:11:54
you would need from the torque tube back and the pump from the front,
C. Amick
05-25-2005 12:52:23
If you look through the information on the web site below, I think you will find a drawing of a 3-point hitch that Case sold as optional equipment for pre-Eagle Hitch tractors.
yeehaw
05-25-2005 13:03:53
 Re: Case VAC in reply to C. Amick, 05-25-2005 12:52:23
Thanks alot....now what do ya think the chances of finding one are?? probably pretty slim to none huh? But hey thanks alot
Pat
C. Amick
05-25-2005 13:18:44
 Re: Case VAC in reply to yeehaw, 05-25-2005 13:03:53
Yes, it would probably be difficult to find one to purchase, but someone that has one might be willing to give you some measurements so that you could get one made.
