Need Help in ID Case 1963 Tractor w/ Loader/Backho
David Jahnke
05-25-2005 09:08:52
I recently purchased a 1963 ("APR 1963" stamped on bottom of foam cushions), was told it was a Case 430, however many things do not agree. A Utility tractor, 12 volt positive ground, with Model 31 Loader (S/N 4069075) and Model 31 Backhoe (S/N 4067552). It is a deisel, with both filter and clear sight glass located directly beneath the gas tank. It has a fuel injection pump of ROOSA Master DBGFCC431-29AJ; RPM-2000; Serial No. 1433074; MFR No. A35775 (which does not match the 430, 530, or 630 shop manual numbers). It has four glow plugs, one for each air inlet plenum to heat the air prior to entering the cylinders, Glow Plug Air Intake Manifold ID 6232; G2112 N2. Engine Block S/N 2003288, CNC; A172. Transmission is Low Dual Range Unit (Hi-Lo), Dry clutch with reverse shuttle unit (eight forward and eight reverse gears). Has separate sumps for transmission and rear axle fluids (guess 85W140 oil came out), one dealer says 380 or 480 CK. I can send photos via email. I believe the key is the fuel injection pump model number noted above? Can anyone please help me find out what tractor this is?
Thank you,
Dave
Ed in Maine
05-25-2005 11:26:32
 Re: Need Help in ID Case 1963 Tractor w/ Loader/Ba in reply to David Jahnke, 05-25-2005 09:08:52
Go the the TRACTOR PHOTOS link at the bottom and upload your pic there. Then just right click on the pic after it's posted, copy the link, and post it in the Optional Image block at the bottom of the post here when you reply. Im interested in seeing a picture of this thing. It does not sound like a 430. Sounds like some type of CK, but not sure which ones were avail in diesel.
Ed
David Jahnke
05-25-2005 13:17:17
 Re: Need Help in ID Case 1963 Tractor w/ Loader/Ba in reply to Ed in Maine, 05-25-2005 11:26:32
Uploaded three photos titled: 1963 CASE in link below.
Ed in Maine
05-25-2005 13:44:08
 Re: Need Help in ID Case 1963 Tractor w/ Loader/Ba in reply to David Jahnke, 05-25-2005 13:17:17
third party image
My vote is for a Case 530, your manual may be for the 'farm' tractor and not the 'utility'? On my 300 series it makes a big difference. By the way, the hyrdo filter (made by Marvel) on the loader control low pressure side is hard to find. You are better off just getting a standard Napa housing and spin-on filter for $15 (just went through this myself last month). The filter is actually cleanable, but mine was crushed.
Ed
David Jahnke
05-26-2005 04:13:57
 Re: Need Help in ID Case 1963 Tractor w/ Loader/Ba in reply to Ed in Maine, 05-25-2005 13:44:08
Thanks Ed. In fact last week I did some searching and the filters are still made by Marvel Eng Co. in Chicago, Ill. They have a min $50 order (therefore you have to buy 3), but can be purchased directly from company if you claim to have a business (i.e. construction or farming). I can't remember the price they quoted me, maybe $18.50 each, so Napa's filter would be cheaper. In my case, I just cleaned it out with diesel and LP air and didn't find any cuts.
