Internals of a DC engine
Trains39
05-24-2005 19:48:52
I purchased this 1948 DC about a month ago and I am just getting around to playing with the engine. It is not frozen, but has not been started in 5/6 years. Cleaned and rebuilt the carb, had starter rebuilt, checked mag for spark, spark plugs for wear. There is spark and plugs show not rust, and are clean. I do have low compression (35 in 1, and 65 in 2, have not checked 3 and 4). I was wondering what kind of pistons this DC would have and what compression should I expect out of a good engine. I am thinking that if the pistons are cast iron/steel and the rings are probably rusted into place. If the pistons are alum then I could possibly have corrossion between the rings and pistons causing problems. Any ideas I am new to tractors but not mechanial workings. I am still waiting for my manuals to arrive.
Ed in Maine
05-25-2005 05:44:50
 Re: Internals of a DC engine in reply to Trains39, 05-24-2005 19:48:52
I would put about a tablespoon of Marvel Mystery Oil into each sparkplug hole and let it sit a bit, then crank here over a few time with no plugs in. Then maybe try a compression test.
This is also a common old timer trick sometimes done when something is put into storage for >1yr.
Ed
C. Amick
05-25-2005 04:39:04
I'd say you are probably correct. The rings are likely stuck in the piston grooves. Have you checked to make sure the valves aren't stuck partly open or shut and checked to make sure the push rods aren't bent. Don L. ([email protected]) should have new rings, etc.
Trains39
05-25-2005 05:28:35
 Re: Internals of a DC engine in reply to C. Amick, 05-25-2005 04:39:04
I am not in a position to pull the engine apart yet. My tuck is in the workshop with the transmission out. I will pull engine apart in the next couple of week. I do not belileve that I have bent push rods or that that valves are stuck. Engine was not stuck in anyway when I got the tractor. No water was found in the crankcase.
Brian in Ohio
05-25-2005 11:23:44
 Re: Internals of a DC engine in reply to Trains39, 05-25-2005 05:28:35
The engine may not be stuck, but the valve are notorious for sticking if the engine has set for an extended period of time. Had that happen to my "L", and ended up replacing two push rods. You don't have to take the whole engine down to check, just take off the valve cover, and crank it over, watching the valve train.
Trains39
05-25-2005 19:07:13
 Re: Internals of a DC engine in reply to Brian in Ohio, 05-25-2005 11:23:44
Took the valve cover off this afternoon. Valves are loose and no bent pushrods. Guess I will have to wait until the workshop is open to pull engine apart.
Trains39
05-25-2005 19:05:54
dctom
05-25-2005 10:31:30
If you can get him to run hang him on a dyno and pull his guts out, rings may losen up and be a good engine dctom
