Case 118 Hydraulic Drive lawn tractor
D Kaufman
05-23-2005 09:47:07
A friend dropped off what was left of Case riding tractor and asked me to replace the belts on it. Does anyone know the proper sizes for the main drive, mower deck and attachment drive should be?
There is not much of any belt to make a guess for size.
Thanks
Dave Riling
05-26-2005 10:30:53
 Re: Case 118 Hydraulic Drive lawn tractor in reply to D Kaufman, 05-23-2005 09:47:07
It is anyones guess but, if your tractor is similiar to mine which is a jacobsen with the case hyraulic rear end...I have a kohler 12 and the belt for the mower is actuated by a electo-magnetic clutch....that wraps around it is about 81 inches or there about...my hyda drive is direct to the pump only a rubber shock absorber between I have no other belts....hope this helps?
D Kaufman
05-27-2005 18:27:21
 Re: Case 118 Hydraulic Drive lawn tractor in reply to Dave Riling, 05-26-2005 10:30:53
Thanks Dave, but this one is different, it is a 8 hp briggs & stratton with not electro clutch. It does have a hydraulic pump/motor at the rear with a long belt extending from the bottom flange of the engine. I have been able to order belts from a original Case dealer, suprisingly enough. Thanks for the input, much appreciated.
