Need VAC Hydraulic Pump Part Numbers
Galen Ishman
05-22-2005 18:44:47
I have a 49 Case VAC with the engine mounted hydraulic pump with a casting # of VT-608 or VT-GO8...I am looking for some good part numbers for the shaft bushings and seal...the bushing and seal on the shaft with the drive gear are shot allowing hydraulic fluid to pump into the engine...Thank You for the help!!
realbeerman
05-25-2005 20:03:01
 Re: Need VAC Hydraulic Pump Part Numbers in reply to Galen Ishman, 05-22-2005 18:44:47
I am rebuilding my pump now and got all bearings and seals from a bearing place they all standard sizes and as far as shaft i getting a insert sleve 0002 and just lock tight it on the shaft where the seal rides
Joe (Wa)
05-22-2005 22:24:00
Casting nr VT608 is the back cover on the distributor ignition engine pump. The pump p/n on a '49 can be either VTA2972 > A29192 or VTA2974 > A29193. The parts below apply to both pumps.
There are no bushings, all bearings were originally Torrington needle type per p/n's below. They rarely require replacement.
Drive gear shaft bearings:
Front = VT4894 > A30587 > Torrington B1012
Rear = VT4895 > A30588 > Torrington B148
Idler gear shaft bearings:
Front & rear = VT4893 > A30586 > Torrington B108
Shaft seal: O4244AB > A26778
Back cover gasket: V20403 > A30760. Gasket will be either plastic or lead on '49, either is suitable. Torque capscrews to 35 ft-lbs.
Pump to engine mounting gasket: VT3691 > A30042.
Joe
Galen Ishman
05-23-2005 07:59:55
 Re: Need VAC Hydraulic Pump Part Numbers in reply to Joe (Wa), 05-22-2005 22:24:00
Thank You very much for the help with the part numbers...My local C-IH Dealer is not very helpful when it comes to anything ...unless you want to buy a new tractor, that is..
Again, Thank You!
