Case 930 1965 Steering problem. Hyd. cyl. remova
Jeff G
05-22-2005 14:58:14
Please help... Does anyone know how to remove the hydraulic cylinder that pushes the plate and tie rods for steering? I removed the 3/4 inch nut on the back side and tried to compress the piston but the cylinder housing hits a cross brace and will not compress enough. The cylinder is leaking badly and will dump a quart of oil in a few minutes. I need to get it off so I can repair/replace the seals. But I can't can't get it out. I'm about ready to use the "hot wrench. Any ideas? Thanks,
Jeff Hilton NY
C. Amick
05-24-2005 09:22:23
 Re: Case 930 1965 Steering problem. Hyd. cyl. re in reply to Jeff G, 05-22-2005 14:58:14
John Saeli can probably help you 315-585-9826 or [email protected].
Jeff G
05-24-2005 12:44:42
 Re: Case 930 1965 Steering problem. Hyd. cyl. re in reply to C. Amick, 05-24-2005 09:22:23
Thanks for the tip. I called John and he was kind enough to give me some good advice. He certainly knows his Case tractors! Tonight I wll try his suggestions. Don't worry, I promise to leave the "hot wrench" in the barn.
