Temp sending unit location on a G148?
Ed in Maine
05-22-2005 11:19:02
I rigged up a temp guage to replace the case guage in the inst cluster on my 1959 310B (will post a pic later). Now I cannot figure out where I can put the "sending unit" for the temp. The only place I can find is where the drain plug screws into the left side of the block just in front of the carb, but I don't want to go without a handy drain plug. Any idea where the factory location was?
Ed
Joe (Wa)
05-22-2005 12:53:28
 Re: Temp sending unit location on a G148? in reply to Ed in Maine, 05-22-2005 11:19:02
Right side of the cylinder head between #3 & #4 plugs.
Joe
Ed in Maine
05-22-2005 15:22:38
 Re: Temp sending unit location on a G148? in reply to Joe (Wa), 05-22-2005 12:53:28
Thanks Joe, would have bit me if it were a snake! For some reason I didn't even think of there being a tap in the head. It is plugged off right now but I think an adapter came with my temp guage to fit.
The tach came free by the way. Ended up widdling down an allen wrench to fit the square female opening and it broke right free. I was worried about crushing the brass collar with vise grips if I used it to break the tach free. PB helped a lot I think, no smudged odo numbers either (thanks for the tip to keep them clean).
Ed
