dc info
SDLoy
05-21-2005 09:57:47
Hello all I'm looking to buy a dc and want to research when some options became available. I seem to recall that the displacement grew after a model year break, can anyone tell me when that was? I plan on using the tractor in our antique puller club (completely stock) but feel that it also has to earn a living around the place. When did hydraulics become available, and how difficult would it be to add them if I find a good tractor without them? thanks Loy
SHeiserman
05-21-2005 20:26:40
 Re: dc info in reply to SDLoy, 05-21-2005 09:57:47
I've got a '49 that had the motor lift (I think that's what it's called). Later I bought a '50 that had hydraulics on it. It's a piece of cake to switch the two rear housings around. Of course, the hydraulics don't work, but it was easy to switch over. The 49 was used with a pto driven pump back in the day to raise wagons. The pump and brackets are still in the shed but I haven't tried that to see if it still works or not.
Mathias NY
05-22-2005 11:05:22
 Re: dc info in reply to SHeiserman, 05-21-2005 20:26:40
I guess I am confused, if the hydraulics don't work why switch the housings over?
I have a 1942 DC parts tractor with a dual spool hydraulic pump on it. The pump is destined for the back of my 1949 D. Does the PTO shaft have to be changed for this? Or is it really just as simple as changing the rear axle cover?
SHeiserman
05-22-2005 14:40:57
 Re: dc info in reply to Mathias NY, 05-22-2005 11:05:22
I wasn't originally going to change over to the hydraulics. By the time I decided to do that, I already had the engine off the '50, so I didn't know if they would work or not. Don't know what the peoblem is, but when I try to use the hydraulics, it just about kills the engine. The pto does work fine, so I'll assume the pump is junk.
I don't know if you have to change the shaft with the housings or not, that's just the way I did it. It was pretty simple, did it by myself.
payne
05-22-2005 16:06:10
 Re: dc info in reply to SHeiserman, 05-22-2005 14:40:57
A good work tractor would be one of the six cylinder 600 models. they are good work tractors and awsome pullers. Even being stock they will rear up and dod a full pull.
John H-WI
05-21-2005 17:08:47
Hydraulics were added in 1949. Believe the hp was kicked up in the mid 40's. We only had 49, 51, and 52 models so can't tell you about adding the hydraulics. Better than the M or A till they came out with the Super M which gave it more horses.
