Oil
Trains39
05-20-2005 12:17:20
I am still waiting for my manuals from YT, but would like to get started doing a few things. One is change the oil, how do you check the level on a 1948 DC and where do you fill it from? The only place that I can find that might be the fill port is on the governor assembly.
C. Amick
05-20-2005 12:56:14
 Re: Oil in reply to Trains39, 05-20-2005 12:17:20
When you get around to changing the engine oil don't forget to drain the engine oil from the clutch housing in addition to the engine oil pan.
c hess
05-20-2005 12:42:43
right top on govenor is correct place to fill. check level at 2 small plugs on oil pan full when up to top plug .low wen none comes out bottom plug. i forgot how much they hold
