Considerable Effort on Adjusting Rear L Axle Beari
cheg
05-17-2005 17:46:09
I recently had to take the rear axle out of my 1937 Case L tractor. I am in the process of adjusting the rear axle bearings. The book says a "Considerable Effort" is required on the adjusting nut inside the wheel hub. I have tightened the adjusting nut with considerable effort and the rear inside bearing is still loose. How much more effort do I need? Will I tear something up if I keep going? I don't want a considerable effort and expense axle repair. Thanks.
Jim Mitteer
05-18-2005 19:03:42
 Re: Considerable Effort on Adjusting Rear L Axle B in reply to cheg, 05-17-2005 17:46:09
I am assuming that you have the wheel or wheel hub tight on the spline? I had to have them on and the locking nut tight before I could adjust the ones on my L.
