Unleaded gas
JGarner
05-17-2005 13:49:13
Just had a thought as I was going through classifieds. How do you rebuilders handle the unleaded gas issue? These tractors were built to run leaded gas. Do you replace the seats with new stellite seats? Can these seats be obtained for old tractors?
Texas Denny
05-18-2005 07:19:01
 Re: Unleaded gas in reply to JGarner, 05-17-2005 13:49:13
That depends. If I don't plan to work a tractor hard and long hours (which is true for everything I have), I don't worry about the valves at all. If I must use a tractor hard, I get additives for the gas. If I have a lot of hard work, I just use the diesel tractor. Seems like additives are the simple solution - easy one because some tractors don't need to be torn down.
L.Lamp
05-18-2005 18:00:00
 Re: Unleaded gas in reply to Texas Denny, 05-18-2005 07:19:01
The SC's and DC's came out with hardened valve seats so unleaded gas is not a problem for them. That is one of the reasons I collect Case's. When I get them rebuilt I can do anything a new tractor could be expected to do.
James S.
05-19-2005 08:45:50
 Re: Unleaded gas in reply to L.Lamp, 05-18-2005 18:00:00
How about the RC's... Would your info pertain to them also?
JGarner
05-19-2005 05:25:30
This is good news! Means I can proceed with my SC search and if I can find a running 53-54 model I will be able to use it for some medium duty work prior a full restoration. Thanks for input!
