Case 830 drain plugs Case-O-Matic
Kerry Livgren
05-16-2005 08:57:35
I just acquired a 1970 830 Comfort King with Case-O-Matic. (from what I read it may be a 69 cause everthing I read says they stopped building the Case-O-Matic in 69) I've been reading these forums and got a lot of good information, but I want to change out the hydraulic/transmission fluid and I am a bit confused about the drain plugs. There is one obvious one beneath the filler cap, but there appear to be two others on the bottom of the case - one just behind the oil drain plug and another further back. Does the Case-O-Matic share reservoir with the hydraulic?
Anyone know about these drain plugs?
Thanks, Kerry Livgren
Kansas
jeffw
05-16-2005 09:59:44
 Re: Case 830 drain plugs Case-O-Matic in reply to Kerry Livgren, 05-16-2005 08:57:35
use the drain plug below the filler and no the hyd is seperate the casomatis the section in front of the trans the trans and rear are together and the hyd are on the back
