tractor problems
vcwireless
05-15-2005 22:25:25
i just bought a model 460 case international tractor. starts fine, great shape, only 1 problem. when it starts it sounds like its laboring however if you move the bucket constantly it runs great, it will then over heat due to the load its running under (what i have been told). looks like a valve somewhere is screwed up, would anyone know where to start looking? or have any other suggestions?
Thanks
L.C.Grey
05-17-2005 19:25:57
 Re: tractor problems in reply to vcwireless, 05-15-2005 22:25:25
If you're not running your loader off the remotes, check to see that one of your remote levers isn't in constant flow position pressuring against the quick connect with nowhere to go.
Ed in Maine
05-17-2005 06:01:52
Sounds like some type of bypass valve malfunctioning? I would start with putting a pressure guage in the system. Not sure where the valves are located in your system. Would think that the over pressure valve would release before the pump overheated though? Just my initial thoughts,
Ed
