Case-O-Matic fluid / ATF
Patrick (Mich.
05-15-2005 22:21:09
I've read comments here in the forum where some of you fellows have said that you prefer to use ATF over TCH fluid in your Case-O-Matic tractors. Indeed, in the manual it states that ATF can be used and specifies type'A'. Since type 'A' fluid is practically obsolete by today's standards, have any of you been using Dexron III instead? It seems to me that all the improvements in the formulation of automatic transmission fluids since the early 1960's would benefit the Case-O-Matic system as much as it does modern automatic transmissions in automobiles. What are your thoughts on this matter? ~Thanks~
Jim Nuhfer
05-16-2005 12:46:34
 Re: Case-O-Matic fluid / ATF in reply to Patrick (Mich.), 05-15-2005 22:21:09
I run Chevron Automatic Transmission Fluid DEXRON-III/MERCON in my Case 801-B case-o-matic. It works great for me.
caseman-d
05-16-2005 11:42:38
I tried hytran in my 800 COM. I'm wasn't happy with the way it was shifting. I friend had a 800 also and and it shifted nicley and he used atf Dextron 3 or equivelent . I was going to change mine to atf but I think I may have blew a head gasket and haven't done it yet.
caseman-d
