rocker shaft on 530 Draft-O-matic
martin in DE
05-15-2005 14:26:34
pulled the piston out of rocker shaft assembly.to find the piston and bore scored deeply.The casting NO. is A37806,will the assembly off a 430 Draft-O-Matic fit. If I can't find a replacement, can the damaged one be repaired.
Jim McVay
05-16-2005 09:37:08
 Re: rocker shaft on 530 Draft-O-matic in reply to martin in DE, 05-15-2005 14:26:34
I have a complete lift cover off of a late model 530 if you need it. $300 for complete plus freight.
Tom (Ks)
05-15-2005 15:13:25
They should be the same. The bore is in too bad of shape to hone out???
