case 470 transmission fluid
Emil 1
05-15-2005 13:39:20
Recently I have purchased 1972 Case 470 tractor. Chenging all fluids. Right under the center of rear axleon the right side there is a drain plug. When I removed it, nothing came out.That scared me. When I checked transmission fluid dipstick, there is plenty of oil.Should these two be connected? Or does differential has its own cavity for oil.How much oil? How to drain transmission fluid then? Thank You. Emil
Tom (Ks)
05-15-2005 15:18:22
 Re: case 470 transmission fluid in reply to Emil 1, 05-15-2005 13:39:20
The hole might be pluged up, poke a screwdriver up in there to break through whatever is there. All of the transmission and differental gears use the same oil.
