Vai throttle/faq
wes s.
09-28-1999 22:53:47
thanks for the tip jerrie.unfortunatly there were
no postings i found to help me but it is full
of lots of other info.forgive me if this is covered ground but im new and dont get on much.
wes s.-1947vai
Jerrie Lott
09-29-1999 06:27:21
 Re: vai throttle/faq in reply to wes s., 09-28-1999 22:53:47
You don't have to apoplogize to me, I'm just one of the many readers of this forum. I think maybe governor problems have been asked about a couple of times, but I don't recall anybody ever giving a good answer on how to adjust a governor on a tractor.
wes s.
09-29-1999 21:55:50
 Re: Re: vai throttle/faq in reply to Jerrie Lott, 09-29-1999 06:27:21
i'd settle for a mediocre answer.do i want butterfly fully open when throttle lever is fully
turned or buterfly closed with lever all the way up or somewhere in between.i,ve moved it so many times,i can't tell where i should be.maybe some one can make a simple drawing and send to my e-mail.thanks.
wes s.
[email protected]
BLR
10-01-1999 12:20:19
 Re: Re: Re: vai throttle/faq in reply to wes s., 09-29-1999 21:55:50
OK here's mediocre. It doesn't really sound like a governor problem. I'm wondering about the stromberg carb. Most VA series tractors had Marvel-Schebler, maybe some of the other guys can elaborate. As for the governor, it usually doesn't cause gross problems. The balls and plates can get flat spots on them which only result in minor inconsistencies in rpm.
The butterfly position will be controlled by the governor when the tractor is running. To increase the RPM you will effectively have to shorten the spring that connects the throttle lever rod to the governor.(e.g. actually shorten the spring or adjust the length of pull on the rod)Before making drastic changes you should borrow or rent a hand tach to make sure you don't over do it.
