pto control
Jeff Garber
05-14-2005 06:25:58
Can anyone tell me how to change the speed of the pto ?
JHH
05-14-2005 21:57:10
 Re: pto control in reply to Jeff Garber, 05-14-2005 06:25:58
What model tractor are you working with?
Jeff Garber
05-15-2005 05:33:16
 Re: pto control in reply to JHH, 05-14-2005 21:57:10
That's my other problem. I don't know what model the tractor is. I have figured out that it has one speed on the PTO, I think. It doesn't stop turning completely but slows way down when I push PTO lever forward. After reading through the archives here, I believe it needs a PTO cluth adjustment. Read on if you are interested in helping me identify this machine.
The serial plate is missing but looks like it was on the bottom right of the dash board. It has holes for 4 gauges, missing one. It looks very similar to a 1959 810B that I saw a picture of on here. I was told it is a 1959 but the previous owner said he doesn't know what model. Maybe it's a collection of parts. The fenders are flat on top with a grab handle at each end. I haven't seen any pictures with these fenders. It has a diesel 6400-A engine. Power steering cylinder is vertical on the left side with the bellcrank. A Lord front end loader is on it.
Here are some numbers from the various castings. PTO case : 6506A, Seat mounting plate : A7364, tranny case : 6480A with a 2 under it, front half of the case (between engine and tranny, bellhousing maybe?) : 6481A, Shifter plate : A7593, Rear axle housing (left side) : 6417A. The rear tires are 16.9-30 "on a 15 inch rim" markings on the sidewall. Front tires are 7.50-16 LT, truck tires.
I just discovered yesterday that it has a blown haeadgasket. It started to get too hot when I was using it. I hope it's not a cracked head or block. I can see tiny bubbles in the top of the radiator when I rev it up. No wonder I got such a good deal on it. Once I figure out what model, I am going to get new head gaskets. Doesn't look like a huge job if I can lift the heads without disturbing the liners. I understand (thanks again to the archives here) that there is a difference in the head gaskets. Stud hole spacing, wide flange cylinder liners verses narrow flange I believe.
I bought this after looking around for a "deal" for a couple of years. Everyone around here was trying to get stupid money for "restorable condition" tractors. I just wanted something that would work for me. It came with a brush hog so I can keep a couple of fields from getting overgrown. Also the loader will allow me to clear the driveway when it snows enough. It won't get a lot of use but I don't want to have to shut it off every 45 minutes to wait for it to cool down. Yes, I am/was an automobile mechanic by trade.
It has the 8 speed gearbox and I heven't figured out yet how to switch from the road range to the creeper range. Guesswork and luck seems to be the only way I've been able to manipulate the single shifter lever to get it to change the speed range.
The other thing is the right side rear wheel is loose, I've tightend up most of the nuts which aren't painted stuck but it still clunks. Do the clips that hold the wheel/rim wear out ?
Thanks for anyone who can help me. This is my first tractor.
Old Eb
05-15-2005 17:21:30
 Re: pto control in reply to Jeff Garber, 05-15-2005 05:33:16
The tranny plate number - A7593 - shows up on my parts list as from a 700 or 800 series tractor. If you look on the bellhousing flange where it mates to the tranny on the left side of the tractor, there should be the serial number stamped onto that lip. It may be under paint, dirt, grime, whatever but it is there on my '61 830. The 700/800 are very similar except the 700 was not available in Case-O-Matic and the 800 was only available in C-O-M. (That was Case version of a torque converter drive.) So...if it does not have the C-O-M drive with the lever mounted under/on the steering column, it should be a 700. I've included a pic of a 700 from the photos. The flat top fenders are from something else.
Somebody help me here if I'm stepping on myself.
third party image
third party image
Jeff Garber
05-15-2005 20:06:02
 Re: pto control in reply to Old Eb, 05-15-2005 17:21:30
Old Eb, I'm glad you noticed. The picture is about right except this case has a Lord front end loader (added afterwards, I'm sure) and a wide front axle. The grill is missing from this one but there is no provision for headlights in the piece above the radiator. I've been looking for pictures of 700s now and they are not plentiful are they ? I'm going to get that Letourneau book probably, if another one I've seen from the American Agricultural Engineers, is not available anymore.
For now, I've decided I will use the tractor for about 45 minutes a day until it gets warmer (new England here). The temp gauge reads accurately, still. When it gets to hot to keep running it without causing damage, I'll shut it off ... leave it parked where it stands, call it a day for the tractor. Just long enough for it to warm up, before overheating. I don't think it will hurt it to sit overnight, outside. Once I can get the proper repair parts, I'll be able to use this piece as it was designed.
Thanks for your help.
Ron - Kansas
05-16-2005 10:36:16
 Re: pto control in reply to Jeff Garber, 05-15-2005 20:06:02
I have a 6 speed 930. I shift to low range out of neutral...I select the (low or high) speed in neutral then shift over to the left for low range and right for hight or road speed. I don't know if there's much difference between the 6 and 8 speed except the extra gears. Hope this helps.
