Vai throttle setting
wes s.
09-28-1999 21:33:03
im, unsure about how to set my throttle/governer
in relation to my carb butterfly.i have moved it all over the place but can't seem to get it right.
it doesn't seem to be high enough rpm when wide open.im just judging by hearing other v-series.
those owners had no input,as they had never played with any adjustments.also,1st gear drags the engine down to almost a die from wide open when slowly engaging gear.do i have my stromberg carb
set wrong or governer or something else wrong?
any help would be wellcomed as i have little
auto knowledge,learning as i go.
thanks,wes -1947 VAI
BLR
10-01-1999 22:26:29
 Re: vai throttle setting in reply to wes s., 09-28-1999 21:33:03
Here's throttle adjustment according to hoyle.
1. Check gov. linkage for free movement
2. place throttle lever and butterfly in full open position. 3. adjust the length on the carb link rod to slightly preload the gov. lever. Generally, this is about 1/16 inch lonnger than needed to connect the carb to the gov. lever.
4. On engines prior to A4700000 use the adjusting screw on the gov. control stop to increase or decrease rpm to 1625 no load. After A470000 use the 2 nuts at the end of the throttle rod increase or decrease the of the gov. sping
wes s.
10-06-1999 18:20:29
 Re: Re: vai throttle setting in reply to BLR, 10-01-1999 22:26:29
thankyou all for your response,especialy "BLR".
as soon as i get my starter fixed(just died,isn't
this fun)or a new one,i will try out this great
advice.
thanks again,wes
Jerrie Lott
10-01-1999 18:07:54
Well I did the only thing I could think of that might help. I own a 1951 VAC and a 1952 VAC14. I measured the length of the governor rod ( the rod that goes from the governor arm to the carb butterfly arm) The VAC has a total overal length of 12 7/16. The VAC14 has an overall length of 11 5/8. Why the difference I have no ideal unless they have different carbs on them, the VAC14 is not running yet and I don't even know where the carb is right off hand. If it was a Briggs & Stratton I could tell you exactly how to adjust the governor but on this I have no ideal.
