Case Model 1194, 47HP, Farm Tractor
Aubrey Morgan
05-13-2005 22:18:51
My Case 1194 Case tractor will not crank. I can start it by shorting across the starter terminals. I have been told that the problem is definitely not the starter but probably is: (1)a defective neutral safety switch or; (2) a safety switch associated with the PTO engage/disengage mechanism or; (3) a safety switch associated with shift mechanism or: (4) a defective ignition switch. I can not locate the various safety switches named. Can anyone help me? Thanks
A. Morgan
Tim Butcher
05-14-2005 09:56:09
 Re: Case Model 1194, 47HP, Farm Tractor in reply to Aubrey Morgan, 05-13-2005 22:18:51
There's also the possibility the starter solenoid is bad. Check power to it by disconnecting exciter wire to solenoid,then holding switch on while testing the wire for power with a test light. If it lights the test light,then that will eliminate safety switches as the cause. Good luck w/it!
