Is this a Case?
Jim Gundlach
05-13-2005 16:39:33
I looked at a used and abused tractor today and efforts to identify it have been unsuccessful. It is a 4-cylinder diesel that looks to be in the 50 to 60 hp range. It has a class I three point hitch and there is a serial number tag on the engine that is blank next to model and has the number 2032587 stamped in it. The serial number tag on the dash is missing. I copied some numbers molded on the larger parts G1411, G1030, and GWCF213, but I forgot to note what part went with which number. It does have the word CASE molded on one part. The owner has painted it green but there are a few places where some red shows through that looks more like the older David Brown red than the Case orange. It has 14.5 x 28 rear tires and they look like they might be a tad narrow for the rims. Much of the sheet metal is replaced with home made substitutes so it is not much help. It has a High and Low range shifter and the main transmission looks like it may have five forward speeds but what I first thought was a �5� really looks more like an �S�.
Any help is appreciated. Jim Gundlach Shorter, Alabama
Jim Gundlach
05-19-2005 09:20:22
 Re: Is this a Case? in reply to Jim Gundlach, 05-13-2005 16:39:33
Time to put a conclusion to this. The tractor was delivered about an hour ago and I went out and looked it over taking George S�s, jeffw�s and Dave Beiter�s posts. Given the tranny case number and that the location of the battery, right behind the dash which is above the hydraulic pump and the size of the fuel tank, and the fuel tank, it is close to an eighteen-inch cube which is much closer to 22 gallons of a 530 than the 13 gallons of the 430, I�ve generally concluded that it must be a 530. Later I will get a web page going dedicated to the tractor and documenting what I do to it. Again thanks for the help. I expect to stay involved with this machine for a good many years and learn it inside and out. It will take a while but I hope to be able to answers others questions sometime in the future.
Jim Gundlach
Shorter, Alabama
Dave Beiter
05-19-2005 19:19:28
 Re: Is this a Case? in reply to Jim Gundlach, 05-19-2005 09:20:22
To see a picture of my 530 (I have 2 now) go to Case tractor photos and under search type in Beiter....That you help you more than anything. Any other questions feel free to send an e-mail
Dave Beiter
05-18-2005 09:25:37
After viewing the photos, it is a late model 430, not 530 as Jeffw stated. The 530 had a larger fuel tank thus making a different hood required. The 530s also had the battery located in front of the tranny shifter. Thus model has the battery under the hood. Correct?
jeffw
05-16-2005 07:01:43
thats a 530
Jim Gundlach
05-16-2005 07:24:02
 Re: Is this a Case? in reply to jeffw, 05-16-2005 07:01:43
JefffW, Many thanks. Jim Gundlach
Jim Gundlach
05-15-2005 17:34:38
I am now certain this is a Case, it is now a question of which one? Some background. The old man who is selling it is 81`and just had an artifical hip put in, he had to buy a shorter tractor because it hurt too much to climb up on this one. The engine starts easy, does not smoke, and has no blow-by. The transmission feels good in all gears. He just had the clutch replaced and the three point hitch had quit working. I went by yesterday and took some pictures. While I was there I talked to the mechanic who was working on the three point hitch. He said it was a good solid, but butt ugly tractor. Here are a few pictures if anyone can get past the green paint and identify it. To see all the pictures simply change the "7" to a 6 and then a 5 and then a 4 ... until 1. Jim Gundlach Shorter, Alabama
Jim Gundlach
05-15-2005 17:36:02
 Re: Is this a Case? in reply to Jim Gundlach, 05-15-2005 17:34:38
Sorry, the URL display did not seem to work:
Link Link Link Link Link Link Link
George S in the real NY
05-14-2005 03:36:03
The trans cast number is used on 530/540 general purpose style tractors. Standard and 530CK backhoe tractor use #G1096. Ref p.200 of parts book that is a mystery number--printed of dealer's computer, for equipment prior to unit #8262800. Tires would be for the "utility style" 530 Ag tractor. Main trans is 4 speed and the S is to engage the start safety switch. The G1096 may have been used on eariler models, I do not have that info.
Jim Gundlach
05-16-2005 07:28:48
 Re: Is this a Case? in reply to George S in the real NY, 05-14-2005 03:36:03
George S, Many thanks for the help. Jim Gundlach
jeffw
05-13-2005 19:44:51
sounds like maybe a 300b 400b or 430 530 ?????are 530 has the s for start and 15.5 28s
CASEPOWER
05-13-2005 18:05:36
G-1030 comes back as a Case transmission case. It don't list the model.
mike's600
05-13-2005 18:14:00
 Re: Is this a Case? in reply to CASEPOWER, 05-13-2005 18:05:36
The S is short for start if it is like my 580B back-hoe.
