case 530ck brakes
james clark9
05-13-2005 12:44:43
doing brake job and now have cover off, need oil seal. there is a plate still on that needs to come off. i do not see any way to get it off, but to split it with a chisle, it has the shimms under it. help,
jim thanks
jamesclark9
05-14-2005 08:34:52
 Re: case 530ck brakes in reply to james clark9, 05-13-2005 12:44:43
thanks for info, i did what u said, it was coming out and looks like a other stuff coming too.
trans oil came out in gushes, what happened??
help, looks like a rubber round thing, 4" dia and 6" long?? may i have been drinking to much!! not really, i am no mchanic. lost maybe 2 gallons??
check out the drawing, it does not show what i saw. will check again.
thanks jim
just 580's
05-13-2005 18:30:42
There is a slotted counter sunk screw that needs to be removed. Then begin working it straight out. There is an o-ring (no. 29 in the illustration) on the inner pilot flange that seals the backing plate to the transaxle housing. That is going to make it difficult to start moving out. Work it out slowly and evenly to keep from breaking it or binding it in the transaxle housing. The link below shows an illustration that may help you see how it looks.
Wayne J.
05-14-2005 05:18:00
 Re: case 530ck brakes in reply to just 580's, 05-13-2005 18:30:42
Hay guys i use parts manuels myself for service manuels if i need reference and it looks like that seal #28 can be removed without removing the berring retainer part #24 with a awl and a screw dent puller. use a length of proper dia. pipe with a clean cut end to reset the new seal if the leak reappears then disassemble and replace the o ring this may save you a little work maybe??? Wayne J.
