vac 14
ky ted
05-13-2005 10:36:31
is there any way to tighten the steering on a vac 14
Jim Yadon
05-13-2005 12:31:46
 Re: vac 14 in reply to ky ted , 05-13-2005 10:36:31
I have several tractors from that style of steering. The biggest problem is there is worm gear that becomes extremly worn. What it was caused from is the grease that was used from the grease zerk in the very front of the tractor has hardned and won't let fresh clean grease get to the worm gear. The one's that I taken apart are basically dry without grease and packed every where else but on the gear so tight that you almost can't cut it out. Since it is almost impossible to find a new gear. What I end up doing is fill in the damaged gear by welding and custom grind to as close as think it originally looked like and haven't had any problems yet. Just want to make sure you don't think it will be an hour quick fix. Good luck
Joe (Wa)
05-13-2005 12:39:11
 Re: vac 14 in reply to Jim Yadon , 05-13-2005 12:31:46
Before you drop dead on this, check you gear box. Later WFE Vac had a fill and drain plug, manual calls for 140 wt grease which is actually gear oil. I have a '53 VAC-13 and use 85-140 in there with not problems or leaks.
Joe
