I need help identifying a Case tractor
Jeff Garber
05-13-2005 04:42:33
I just bought a 1959 (I am told) Case tractor and I have no clue what model it is. Hopefully someone might be able to help me. I can supply digital pictures if needed.
It has a diesel engine with compression release, no glow plugs. There is a Lord front end loader with down pressure on it. It has power steering, 2-wheel drive, 3 point hitch and there is a power take off on the rear. The hydraulic pump is connected to the front end of the crankshaft. The engine block has the number "6400-A" cast into it just under where the firing order is.
Jeff Garber
05-22-2005 07:55:13
 Re: I need help identifying a Case tractor in reply to Jeff Garber, 05-13-2005 04:42:33
I spotted a 410 Case tractor. According to the decal on the loader arm this one (at a local flea market) is a 410. The serial number plate lists the model as a 435 Model. This tractor is about half the size of the one I have.
Does this new information help make it easier for me to identify which model I have ? Asking price for the one a tthe flea market is $3500.00, gas engine, not a 6400-A block, if anyone is interested. It is in Massachusetts.
Butch/ OH
05-16-2005 18:40:24
That block number indicates that it would be a 400, made from 1955- 1957.
Jeff Garber
05-16-2005 19:32:45
 Re: I need help identifying a Case tractor in reply to Butch/ OH, 05-16-2005 18:40:24
Butch,
I have spent some time now on this "project" and it seems you are right. This is probably a 400 of some sort. Maybe an industrial version. I've gotten some information from several sources and helpul individuals like yourself. The previous owner may not have the year straight since he bought it only 3 years ago and didn't do much with it. Thank you for your thoughts.
I just ordered a shop manual for the Case 400 series which supposedly covers all. I'll keep my fingers crossed until it arrives. If it's the wrong book I'll have it up for auction on eBay quicker than the dandelions grow around here this time of year. If it's the right book, I'll be looking for good deals on the parts manual and the operator's manual, next. Then on to new headgaskets and maybe a few other items that need attention. I'd rather spend the time now to make this machine dependable and then use it until I'm done. Gotta start with figuring out what it is first.
Thanks again
