timing on JD 350 crawler
tbird505
05-12-2005 14:55:44
Does anybody Know the firing order and where #1 lead is on the distributor on a JD350 crawler THANKS
jdemaris
05-12-2005 20:04:00
 Re: timing on JD 350 crawler in reply to tbird505, 05-12-2005 14:55:44
Odd question to ask in a Case forum. Deere 135 c.i. gas engine firing order is 1-2-3. Number one terminal is as such: - distributor is installed with the primary wire (from the coil) facing the cylinder block. Looking down at the distributor where said wire is, and going clockwise, the number one terminal is approx. 50 degrees (to the right going clockwise).
