Headlight part number 311
Sam F.
05-11-2005 08:34:01
Anybody know the part number for the Case 311 round nose sealed beam light ??? Just the seal beam, no bucket, etc. 6 volt and where to buy ??
C. Amick
05-11-2005 09:42:58
 Re: Headlight part number 311 in reply to Sam F., 05-11-2005 08:34:01
There have been lots of discussions on this forum about this topic. The correct size lamp is no longer available. Use a smaller 4-1/2 inch 6 volt sealed beam which should be available at your local auto parts store. I split rubber vacuum tubing down one side and open it up and glue it to the lamp with silicone. I use a big band clamp to hold it in place until the silicone dries. The vacuum tubing that I use is pretty small. The metal headlamp band doesn't want to fit back on correctly, if you use the larger tubing. The rubber tubing does not show. The other option is to replace the housing with a Farmall or JD size housing.
