Neighbor's 89 Case 585 clutch R+R
Pooh Bear
05-10-2005 18:48:40
Friend has a 89 Case 585. It needs a clutch.
He asked me to look into getting one.
Where should I look and how much can I expect to pay for this.
How hard would it be for the two of us to change a clutch.
I changed plenty of clutches in my old truck over the years.
What is the basic procedure for this tractor.
Thanks for any info you can give me.
Pooh Bear
Mac
05-11-2005 06:08:49
 Re: Neighbor's 89 Case 585 clutch R+R in reply to Pooh Bear, 05-10-2005 18:48:40
Hey PBear, [email protected] and ask for Nick. Walts Tractor parts was priced good also.. I was forwarded to Nick through BARE CO which has a website. CaseIH wanted about 450 bucks for kit. Another hint since you was askin, is tie up pedal so TO carrier is far back as it'll go and put press plate and disc on trans shaft splines. Then you just stab shaft to pilot and mount press plate to flywheel through dust cover. A lot easier than trying to stab all 3.
Pooh Bear
05-12-2005 15:18:06
 Re: Neighbor's 89 Case 585 clutch R+R in reply to Mac, 05-11-2005 06:08:49
I emailed Nick at that address yesterday.
Haven't heard anything yet.
Pooh Bear
Pooh Bear
05-11-2005 09:20:21
Thanks.
My neighbor said he would probably hire it out to actually change it.
But if he can save some money on buying it that would help greatly.
Thanks for the info.
Pooh Bear
L.C.Grey
05-10-2005 20:22:46
I had the clutch replaced in my 574 this winter at my local Case IH dealer. I believe the 585 is the same engine/chassis/transmission/rearend with newer sheetiron and more features.
They had mine in and out in a day and a half, surfaced the flywheel, new disc, new pressure plate, new throwout bearing, new crankshaft main seal, 3 other new seals in the tranny input shafts and pressure washed it, all for under a grand. I felt like they done good!
L.C.Grey
05-10-2005 20:24:31
 Re: Neighbor's 89 Case 585 clutch R+R in reply to L.C.Grey, 05-10-2005 20:22:46
Ooops... forgot the new pilot bearing. They did that too.
Mac
05-10-2005 19:50:12
SPARE TRACTOR PARTS OF TN,INC, 250 for plate, disc TO and pilot and 12 UPS. That was for organic, instead of button clutch. I just split mine singlehanded in half day few weeks ago. I used floor jack on 3/4 plywood to support front half and block up back half. A lenght of 1/2" allthread each side help align everything back up. Need to wedge axles and bolster to prevent tipping and a small comealong to split her. Need a hoist etc for flywheel and have it machined (face and press plate mount surface same amount) I set up new clutch with freeplay instead of constant mesh to bearing using 84 series spring and 1/4=20 bolt for adjust.
Pooh Bear
05-11-2005 09:23:12
 Re: Neighbor's 89 Case 585 clutch R+R in reply to Mac, 05-10-2005 19:50:12
...was for organic, instead of button clutch...
What does that mean, organic instead of button clutch.
What is an organic clutch.
What is a button clutch.
I have never heard these terms before.
Can you enlighten me just a little?
Thanks.
Pooh Bear
JakeF
05-11-2005 13:25:04
 Re: Neighbor's 89 Case 585 clutch R+R in reply to Pooh Bear, 05-11-2005 09:23:12
Organic means it's an organic lining not metalic or ceramic, although some organic linings have imbedded meatal in them. A button clutch will have 3, 4, or 6 small pucks with lining and the rest will be missing. The button clutches will hold more power but don't engauge as smooth and shouldn't be slipped. For tillage work a button is better, but on a loader tractor that gets the clutch used and slipped a lot they are not as good of a choice. Jake
Pooh Bear
05-10-2005 20:13:08
Do they have a website.
Or how can I contact them. Where are they located.
I just got a clutch kit for my 8N.
Ordered from someplace in North Carolina.
But I got a good price on it. totaled $161.
Sounds much like the same procedure to install it.
I spent all day yesterday splitting my 8N.
Will spend tomorrow putting it back together.
Are there other places to get this.
I like to shop around and look at websites.
Pooh Bear
