Bruce Nelson; I need HELP!!
DKase
05-10-2005 17:14:37
Had the local machine shop install new guides and seats in the heads for the 336 diesel for the W14 loader. They did not cut them in deep enough. The valves stick .060" down into the compression chamber. If I leave them there there will be 0 clearance to the piston. It took me 1 hour to grind the intakes down to flush with the most course stone I could find. That was a piece of cake!! I have spent the last 5 hours grinding on the exhaust seats and I have 1 down to spec! Do you have a better way to cut these stellite seats down? They are harder than h@11! HELP DK
Bruce Nelson
05-11-2005 05:32:33
 Re: Bruce Nelson; I need HELP!! in reply to DKase, 05-10-2005 17:14:37
DKase, e-mail me. Bruce
george md
05-10-2005 20:53:41
DK, My AERA cylinder head manual says 0 to .040
recession.
george
John Saeli
05-10-2005 19:18:08
I don't think .060 would have given you any trouble, and you shouldn't be grinding them down flush.
DKase
05-10-2005 19:37:14
 Re: Bruce Nelson; I need HELP!! in reply to John Saeli, 05-10-2005 19:18:08
The piston is .050" below the top of the block. The head gasket is .060" thick not compressed. The valves stick into the compression chamber .060". The valves are both open .050" on TDC of the exhaust stroke. This is all with the engine parts cold. Do the math! I dare you to try it with your engine. Spec calls for 0 to -.060" protrusion. DK
John Saeli
05-11-2005 04:26:13
 Re: Bruce Nelson; I need HELP!! in reply to DKase, 05-10-2005 19:37:14
Hey DK. I failed Math!!!
