Case 411 rebuild
markloff
05-10-2005 14:33:09
My Case dealer says that they have discontinued the pistons for a 411 (diesel) rebuild kit. I would like to do a full rebuild with pistons and sleeves. I also would like an increase in power and displacement.
What can I do? Will the 830 rebuild kit work at 301 cubic inches? Any other options? Was the 411 originally steel or aluminum pistons? Can you convert to aluminum pistons?
I also think that a larger displacement with the original heads will bump up the compression ratio and help with cold weather starting. What do you think?
Thanks, Mark
jeffw
05-10-2005 14:57:21
 Re: Case 411 rebuild in reply to markloff, 05-10-2005 14:33:09
they have the 267 400 d kits is yours a 267 or a 251
jeffw
05-10-2005 14:55:43
check engine kits on this site
