DC experts-- for JDB
L.Lamp
05-10-2005 10:24:12
The DC you were looking at could be a late '51 model. Case used the same transmission housings for the last of the '51 year they used for the new eagle hitch '52 model. I have a late model '51 SC and I am installing an eagle hitch on it. Bushings for the rock shaft can be had at Precision Industries, a bearing supply outlet. You will need to modify the drawbar to install the eagle lift cylinder, and the draft arm brackets. It's best to have a 2 valve pump also, something my '51 had.
JDB
05-11-2005 10:24:25
 Re: DC experts-- for JDB in reply to L.Lamp, 05-10-2005 10:24:12
Thanks L.Lamp Both my DCs have dual hyd and eagle hitch from the factory. One of them is just missing the cylinder. Appreciate the bushing info
