VAC Hyd, reservoir??
gpogpo
01-11-2006 16:16:01
My VAC has only the hyd. pump under the belt pulley housing. I have a low pressure pump to install in the cam gear housing but can't figure how to use the torque tube for its reservoir as the book describes. The tractor has no openings in the torque tube for this purpose that I can see. Can I do it somehow?? Or will I have to add an external tank? Your thoughts most welcome!
C. Amick
01-12-2006 09:54:19
 Re: VAC Hyd, reservoir?? in reply to gpogpo, 01-11-2006 16:16:01
I think the VAC's that used the torque tube as a reservior had the pump mounted on top of it. I think it is a different casting from the belt pulley pump models?
mj
01-12-2006 08:19:39
third party image
You can use the torque tube..... pic is #25 on the link..... click the link for more and click an image to enlarge and/or print. There is more info on the site on the factory setup in 'Manuals/hydraulics'.
gpogpo
01-12-2006 10:49:53
 Re: VAC Hyd, reservoir?? in reply to mj, 01-12-2006 08:19:39
Mike, your photos are going to be a tremendous help to me. Thanks very much! I see that my torque tube casting is different than the one used as a reservoir for the low pressure pump. I'll probably just add an external tank. The photos of the 3-pt hitches will also be helpful as I will need to fabricate one--unless I decide instead to build a front loader like the one photo showed.
Gary Cash
01-11-2006 23:29:04
The "belt pully housing" on my VAC is my only hydraulic reservoir.
