case va pre-eagle hitch
jon holt
05-08-2005 22:05:20
I was wondering if parts were still available for the pre-eagle hitch on case va series tractors. Mine uses a two way cylinder under the tractor run by a pump off of the timing gear at the front of the motor. I am needing the adjusting arm on the right side and the anti-sway bars for the lift arms. Thanks for any info
Jerry W
05-09-2005 11:59:00
 Re: case va pre-eagle hitch in reply to jon holt, 05-08-2005 22:05:20
I guess I was unaware that any system was used that utilized the cam case driven low pressure pump. I just assumed that they all operated off of the belt pulley hi-pressure pump and rock shaft like one of mine does.
Jerry
C. Amick
05-09-2005 08:24:57
I think this hitch was made for Case by a company in CA. I don't think you can still get parts for it. Below is a link to a VA parts manual showing a drawing of this hitch. Perhaps you can have the parts you need fabricated.
Jon Holt
05-09-2005 19:35:57
 Re: case va pre-eagle hitch in reply to C. Amick, 05-09-2005 08:24:57
yep that is the hitch that I have. I would probably expect that there weren't many of these built seeing as how I have seen hundreds of the eagle hitch and maybe only three of these. If you can get past the light duty arms it is a nice lift, even has two way cylinder which I like a lot
