value estimate help needed
JimAK
05-08-2005 18:11:39
Hi- I usually am on the Ford side looking for info on my "71 4500 backhoe but a friend is looking at a 1992 580K 4x4 and he asked me to look it over for him. I am no mechanic but had an idea what to look for having just bought mine last year. Knowing what a great and useful site YT has been for me I decided to try here for some input. Here is what I found after a quick look:
General codition good but well used. Had an equipment rental logo on it, probably original owner. 4 cyl. diesel, started instantly and sounded good throughout testing. Throttled up and down smoothly. No smoke. Usual signs of oil seepage and fuel seepage on engine that has not been kept clean but no active drips/seeps while running.
Shifts in and out of 4WD ok, just stiff.
30" bucket.
Backhoe and loader pins/bushings in pretty good shape.
New front tires, one new rear tire. Other rear tire is maybe 10%. Is this a concern if machine is only used off-road?
With the exception of swing pedals, all hoe and loader controls are smooth and strong. (I was amazed at how simple and intuitive they seemed by comparison to those on my 4500.) I lifted the machine off the ground easily with hoe and bucket and there was no sign of bleed down over about ten minutes.
Bad stuff-
Swing pedals work but are very stiff and sticky. I am assuming that they are spring loaded and should stop when pressure is released but usually had to activate opposite pedal to stop swing. Prob. just clean and lube the moving parts?
Needs new seat assy as swivel mechanism is shot.
Parking brake not working, lever still moves easily but no brake.` Could be simple adjustment I suppose.
Throttle lever and 4-speed shifter very stiff, but both work so maybe just clean and lube linkage?
Stabilizers both work though one side need a new fitting and the other a new steel tube that brings the oil.
There is some electrical issue. The ignition switch is gone and is just a sprout of wires that are hot wired to start. Owner unhooks batt cable between uses. However, head and worklights are working, as are some guages (not oil temp)including amp guage which says it is charging fine.
Rear wheel bearings seemed ok. The worst stuff I found was up front. The left front u-joint was worn out completely, and the (I don"t know the proper term for these) king pins or spindle pins/bushings are worn. I am talking about the two points where the wheel joins the axle. There is an upper and a lower one, and there are bolt on cover plates to access them. The right u-joint seems ok, but the upper previously referenced bushing is worn, and the lower appears to be completely gone as it is very loose.
I just realized I forgot to get the engine hour reading. I will try to get back with that but want to post this for now.
Reference #"s from plate on engine:
Model 4-390 Par(?)# 989067C1
Ser.# 44516657
That"s about it. Owner is asking $15,000. When my friend talked to him he seemed willing to come down a bit. The front end problems were not part of their discussion.
My guess is the price is fair, but I am not sure of the difficulty/expense of the front end repairs, or the general market for used Case equipment. Is this asking price in the ballpark given the known downsides?
Thanks for any input you can give. Jim
