water pump stuck
Wayne G
05-08-2005 01:59:47
I have a 1952 DC with a bad water pump. The problem is, the water pump is unbolted, but stuck in the block. I hate to use too much force, in fear I might damage the block. Any help from anyone greatly appreciated. Please email.
Wayne
Wayne G
05-08-2005 14:38:16
 Re: water pump stuck in reply to Wayne G, 05-08-2005 01:59:47
Thanks Jim, sounds like it will work, will get stuff to do it with monday, will let you know if I"m successful.
Wayne G
Jim V.
05-08-2005 02:25:46
Wayne, just removed the pump from my DC yesterday, same problem. I used a piece of angle iron, cut out to fit behind pulley flange and drilled for two bolt. Put bolts in with heads against block and head with nuts behind angle iron. Use the nuts to push the iron out. Came out without much effort. As you tighten the nuts and put pressure on the pump, doesn't hurt to tap on the pump with a hammer some. The pump only has to move about a half inch and it basically falls out of the block. Hope this helps.
Wayne G
05-09-2005 07:44:48
 Re: water pump stuck in reply to Jim V., 05-08-2005 02:25:46
Thanks Jim, had the pump out by 10:30 est., came out in several pieces, but it's out, and no block damage.
Wayne G
