Value of Eagle Hitch?
Rauville
05-07-2005 18:10:59
I haven't looked at older Case tractors for awhile, so need some help. I'm thinking about a late model DC w/ wide front, foot clutch, etc., but no Eagle Hitch. How does the lack of that option effect the desirability and value?
Thank you
L.Lamp
05-08-2005 11:23:31
 Re: Value of Eagle Hitch? in reply to Rauville, 05-07-2005 18:10:59
The eagle hitch does not interfere or limit ordinary drawbar use in any way. I would buy one with the eagle hitch. Once you got used to it, you wouldn't have it any other way. If you didn't like it it can be removed, but I would see that as a remote possibility.
Rauville
05-08-2005 15:11:22
 Re: Value of Eagle Hitch? in reply to L.Lamp, 05-08-2005 11:23:31
It just so happens that the DC that I'm looking at appears to have been made without the Eagle Hitch. The "rock shaft" is there, but the ends are covered with factory plugs/covers. The tractor itself is a very late model DC, and lack of the hitch is puzzling to me. I am just curious as to how much of a "deduct" it would take off the value.
Thanks for your advice; if I buy the tractor, I'll be back for more.
Glenn F.
05-08-2005 16:16:01
 Re: Value of Eagle Hitch? in reply to Rauville, 05-08-2005 15:11:22
My brother has a late model DC with hand clutch. It also has plugs in the rock shaft holes. My '53 came factory hand clutch with eagle hitch. I am switching it over to foot clutch. Glenn
Glenn F.
05-08-2005 07:17:30
Well it's all in what you want. Personally I think a DC with foot clutch and eagle hitch is the cat's meow. I have never seen a foot clutch DC without eagle hitch but I'm sure they're out there. The rear casting would be designed for one if it is a factory foot clutch. Clearly the eagle hitch will increase its value, but this isn't a money making business. Buy the model You like. My thoughts. Glenn F.
