case 841 three point hitch
Rancher824
05-06-2005 20:30:03
Hi, I have purchased a case 841 propane tractor for using around my 60 acres. I have planned for it to work a boxblade as well as other 3 point impliments. My question is, and I admit I am very dumb about all of this, when I put the boxblade on I am having problems with getting it leveled correctly. It has the case arms that do not swing. I have bought a top link that is about 2 feet long. I have tried it all the way in to get the back of the blade up when it is raised, but when I drop it to the ground the top link falls far enough to hit the hydrolic lever. I let it out part way, but then it just barely gets it off the ground when raised and sits at an awful angle. Do I need a differant top link? Does my boxblade not fit right? As I said I am very dumb. On the lower arms one of the couplers is broke. Where would be a good place to find a replacement. Also is there somewhere I can go with my serial number to find out when it was made? Thanks for any help you can give. Ronald
DKase
05-07-2005 18:46:39
 Re: case 841 three point hitch in reply to Rancher824, 05-06-2005 20:30:03
If you have trouble finding the PTO cover top link connector you can get the same effect by extending the top link connector up on your implement so the top link is parallel with the lower arms or even higher on the implement. DK
Rancher824
05-07-2005 17:09:33
The help is very much apriciated. I am starting to get an idea as how to get things working. I do have one more quick question. I know how to check the oil, and the oil bath for the breather. I am not sure though how to check the transmission fluid, or hydrolic oil. I have gotten the idea they may be the same, but not sure. Thanks so much for the help. Ronald
Roger H
05-07-2005 19:03:19
 Re: case 841 three point hitch in reply to Rancher824, 05-07-2005 17:09:33
Ron, when you are sitting on the tractor there is a breather cap just to the right of your left foot, the transmission & hydraulic are the same, if your 830 is a Case O matic there will be another breather cap on the left side below the propane tank, check that oil level right after stopping the engine
sidro
08-10-2006 15:52:45
 Re: case 841 three point hitch in reply to Roger H, 05-07-2005 19:03:19
Roger H
you wrote; Ron, when you are sitting on the tractor there is a breather cap just to the right of your left foot, the transmission & hydraulic are the same, if your 830 is a Case O matic there will be another breather cap on the left side below the propane tank, check that oil level right after stopping the engine.
What I need to know is how and where you put oil in the hydrolics and where to check it.
Any help appreciated. Thanks
c hess
05-07-2005 06:54:42
There is apto cover listed on e bay that you might (will need) you can yery easy bend control leavers if you hit them with top link. you might have to look at a couple pages on e bay to find pto cover.
Rancher824
05-07-2005 09:02:26
 Re: case 841 three point hitch in reply to c hess, 05-07-2005 06:54:42
thanks for the info. I have looked, but am not finding it. I found a safety cover. What key words should I search for?
Roger H
05-07-2005 05:50:12
What you have is the Eagle Hitch 3 point on your tractor. Are you having trouble getting it level side to side? if so there should be a crank at the top of the linkage going down to the lift arm. It sounds like you have the top link attached to the tractor above the hydraulic pump if the link is hitting the levers, there is another bracket that bolts on over the pto shaft that gives another place to attach the top link, that is probably where you need to put it to get it to lift right. I have the blade on my 830 right now, if you want I can take some pic's & email them to you so you can understand what I have said. Post your serial number & I or someone else can look it up, mine is 8193616 & it was built in 1962 & it is propane too.
Rancher824
05-07-2005 08:42:25
 Re: case 841 three point hitch in reply to Roger H, 05-07-2005 05:50:12
That is a lot of help. I do not have the lower bracket. I just called a dealer and they are checking on it. The pictures would help as well. The serial number is 8169122. My email is [email protected]. Thanks so much.
Roger H
05-07-2005 10:32:26
 Re: case 841 three point hitch in reply to Rancher824, 05-07-2005 08:42:25
Ron the 2 items on Ebay are #7513477860 & 7512934846, the top link is the one for early 830's, I'm not sure if the 3pt bracket is the same for the 400 series & 30 series,if I had a 400 parts book, I could find out. Your 830 is a 1961. I'll get some pics shortly
