What's This 300 Worth?
Glenn FitzGeral
05-06-2005 08:35:52
A neighbor of ours has a 300 CASE he's willing to sell me in exchange for my helping him with his field work. I don't know a lot about the tractor, but here goes...gas engine,mechanically sound, wide front, tripple range, decent (complete) tin, rear tires shot, no power steering, eagle hitch, seat torsion spring shot, tractor does not look too pretty but has been in service until recently. It would need quite a little TLC. Approximately what is this tractor worth? I'm in Wisconsin. Thanks, Glenn F.
C. Amick
05-09-2005 04:23:40
 Re: What's This 300 Worth? in reply to Glenn FitzGerald, 05-06-2005 08:35:52
I gave $1,600 for mine which was in similar condition.
Glenn/Mn
05-06-2005 14:03:21
Straight West of you I bid last year on two of them with loaders $1,750.00(311)and $3,100.00 (310)I was brides maid on both. Down south took one to $2,250(311)and I was brides maid again. None of them in that great of condition. Good luck!
Glenn F.
05-06-2005 16:16:12
 Re: What's This 300 Worth? in reply to Glenn/Mn, 05-06-2005 14:03:21
Interesting. I'm sure I've read it here before but what's the difference between a 310 and a 311?...Probably narrow and wide front...? Which is worth the most? Thanks, Glenn F.
Joe (Wa)
05-07-2005 11:11:46
 Re: What's This 300 Worth? in reply to Glenn F., 05-06-2005 16:16:12
The 311 is the GP version, can be either 2 tire NFE or WFE. Adjustable front axle that is tubular with vertial spindles. Rear tread is also adjustable.
310 is the utility version. WFE only with non-adjustable I-beam front axle with yoke type spindles. Rear tread is fixed.
I have one of each, can't think of any other significant differences at the moment.
Joe
Walt Davies
05-06-2005 09:28:22
With the real wheels shot you need to figure about half what you would normally pay and hat would be abouy $700 average. they range from $400 to $1200 in Fair poor condition. If yours is running then that's a plus so add some to for that. The tires alone will cost you about $75 for the front and $400 to $500 for the rear. If you can get a used set for the rear about $100 ea. then that would help. Its a lot like what you want to pay and what the owner will let you have it for so just make alow offer and work up from there. If you are doing work for it you can alway pay a little more than its worth just to make the owner happier without hurting your pocket book. Walt
PS I paid $250 for a non running Case LA in fair condition as far as the body goes and $1500 for another one that was running so its alot like what you can get the owner down to. Horse trading is lots of fun ain't it.
Ed in Maine
05-06-2005 12:16:21
 Re: What's This 300 Worth? in reply to Walt Davies, 05-06-2005 09:28:22
Here in Maine that 300 would go for about $1,000, but I would try to get it for $800 and maybe put a couple hundred into some used rubber. A loader would double its value, if you ever came across one to add on. My 1959 310B (300 series) with loader & backhoe would go for about $3500 here. I say go for it! They are relatively easy to work on, just get you a great big crecent wrench...
Ed
