VA has fluid now
swamp farmer
05-06-2005 06:36:19
I took the advice that was given to me here last week about replacing the hydraulic fluid. But here's what I learned: I was advised to fill the resevoir to the fill hole. I started up the machine, let it warm up (it's still cool here), and began to run the wood splitter. Half an hour later, I had hyd oil dripping out from any number of joints in the area of the fill hole. When heated does the hyd oil expand a bit? I ran the splitter until I ran out of fuel, about an hour, and saw that no more hyd oil was leaking. Did I fill it too much, or do I just have a leaky mid-section?
thanks again.
Joe (Wa)
05-06-2005 11:38:59
 Re: VA has fluid now in reply to swamp farmer, 05-06-2005 06:36:19
Yes the oil will expand signicantly used on something like a splitter.
Try to determine exactly where the leak is. Most likely it is misting out of the breather. If there are other leaks on the torque tube the breather is probably plugged, allowing a buildup of pressure. Monitor you transmission oil level, any pressure in the torque tube can force the hyd oil back through the drive shaft seals.
Check the oil level now that it has cooled down, should be filled to the lip of the fill plug opening. If it is close to full, not more than an inch down, it will be ok at that level. Another option is to plumb the the breather higher if that is the leak.
Joe
swamp farmer
05-09-2005 18:54:42
 Re: VA has fluid now in reply to Joe (Wa), 05-06-2005 11:38:59
The fluid level is fine now. I might have lost 6-8 oz, and then it stopped. many thanks for the advice
