Case SC thermostat
Jim V.
05-06-2005 02:12:11
I need a thermostat for an S model Case. Dealer, who has been helpful, says they are no longer available and can't find any after market suppliers. Any one have any ideas?
C. Amick
05-09-2005 04:27:52
 Re: Case SC thermostat in reply to Jim V., 05-06-2005 02:12:11
If the one you buy is a little too large in diameter to fit the hose, you can trim it with a pair of metal cutting pliers.
L.Lamp
05-07-2005 09:54:22
My solution to that problem is to install a new upper hose. Take the new hose to an auto parts store and find a 180 thermostat that will fit snuggly inside the hose. Put the bulb end toward the engine with the thermostat about 3/4" from the bottom and slide the hose onto the tractor fitting. You will have to work to get the upper end on but don't pull the hose back up. Put a good clamp on each end with the bottom on about 1/8" up from the top of the tractor fitting. I have three of them that way and they work good.
Jim V.
05-09-2005 03:30:07
 Re: Case SC thermostat in reply to L.Lamp, 05-07-2005 09:54:22
Thanks, I'll give that a try. Appreciate the help.
