thermostat
mikefromiowa
05-05-2005 12:27:46
Ok, I have a stupid question. I am going to replace the thermostat in my VAC. I know that its supposed to start opening @ 150 and be fully open @ 175. Ok. That being said. NAPA has one that is 170 and 180. is that the fully open temp or the start to open temp. He said it was the fully open temp.
Mike
mikefromiowa
05-06-2005 06:07:24
 Re: thermostat in reply to mikefromiowa, 05-05-2005 12:27:46
Thanks. I'm going to take back the 180 degree and get the lower one.
Joe (Wa)
05-05-2005 16:06:37
The 170� t-stat will crack (start to open) at 170�, will be fully open about 175� and then will be fully closed again about 165�. Those are ballpark figures, t-stats vary even within the same brand. The function is to hold the temp close to 170�. You can prove that by putting it in some water, heating & cooling several times while observing it function. Don't expect it to be perfect.
The original VAC t-stat was a slow reacting bellows type. Modern amot type t-stats react faster.
Joe
Greasey Hand
05-05-2005 14:59:36
Thats wright opens at that temp.
