Case 2090 power shift
Hayman
05-05-2005 06:57:36
My 2090 seems to not shift as smoothly as it used to. It's sure not as smooth as my 970.
I don't know if its just me but it seems to "pause" a bit too long before it shifts into the next gear. Like when your going from 1 to 2 and especailly from 2 to 3.
Has anyone adjusted this? I believe its a matter of making an adjustment on powershift valve body.
nna
05-06-2005 04:27:51
 Re: Case 2090 power shift in reply to Hayman, 05-05-2005 06:57:36
This may sound a little strange but the cable that goes from the power shift lever down to the valve could be binding. If it drags, even slightly, it can affect how quickly the spool works in the valve body and how smoothly the power shift works. The cable is a little over $100 but it can may a big difference.
Can't even use my name
05-05-2005 21:25:39
Turn the adjustment screw on C3 port about an 1/8 turn clockwise till it is better. Supposedly you need the gauge setup to properly set the valves but this will work for now. C2 is for the down shift adjustment.
