Dc case carb
ted
09-27-1999 17:22:22
What are the settings for the carb. It runs good without a load but it is rough when trying to move it. Also, how do I set the linkage between the governer and carb. I put a new tie rod end on it and am not sure where to set it, I think this is part of my problem too.
Jeremy
09-29-1999 13:03:44
 Re: dc case carb in reply to ted, 09-27-1999 17:22:22
To set the linkage between the govenor and the carb, first unhook the rod from the carb. Next set the throttle in the wide open position (don't do this with the tractor running). Then set the carb throttle shaft and butterfly in the vertical (wide open) position. Now adjust the rod until it is a 1/2 hole to the rear of the linage hole on the throttle shaft. Hook everything back up. This will allow your govenor to do its job. Now readjust your idle speed and set the main engine speed as described in the manual.
Rich
09-28-1999 19:02:15
I posted the carb adjustment from the owners manual at: http://members.aol.com/case49dc
