Case Mag Help
Jivan
05-04-2005 10:13:40
I am reassembling my magneto (4JMA). On the fiber cam there is a red dot. Can anyone tell me if the dot should be up or down or doesn't matter? Thanks.
Glen in TX
05-04-2005 12:31:32
 Re: Case Mag Help in reply to Jivan, 05-04-2005 10:13:40
The dot on the cam and gear are suppose to face out but you can turn the cam over if it is worn some and reset points and timing. The dot on the steel gear lines up with the beveled teeth on the dist. rotor gear. The beveled teeth on dist. rotor gear should face out or towards the dist. rotor.
