sc draw bar hanger removal
jstpa
05-03-2005 15:44:12
Not sure if I used the right term in my subject or not, but I am trying to remove the piece that the swinging draw bar hangs on at the back of the tractor. I removed the four bolts holding it to the pump reservoir and the 2 bolts that go into the tranny housing, It just hangs off of where I took the 2 bolts out of the trans housing but wont come off. The tractor is equipped with eagle hitch if that makes a diffrence. Thanks for any help, jstpa
C. Amick
05-04-2005 04:20:15
 Re: sc draw bar hanger removal in reply to jstpa, 05-03-2005 15:44:12
The two ferrells that DCTom referred to are on the bolts that you took out along the right and left side. The ferrells go through the drawbar bracket and into the tractor housing and they can be a pain to get out. They should just slide out, but are probably rusted in there.
dctom
05-03-2005 16:48:04
there are two ferrels in the houseing that have to come out all the bolts do is hold them in tom
