DC CASE
JDB
05-03-2005 10:24:39
Anyone see the DC with the wide front in the photo ads section? Are those the right rims on the front? The rims on my wide front look like implement rims.
PaulL
05-03-2005 15:15:29
 Re: DC CASE in reply to JDB, 05-03-2005 10:24:39
I have four DC's with wide fronts and three have pressed steel wheels and one has cast. I'm sure someone else is more of an authority on this than I but it looks like the late model DC's had the cast wheels. My cast wheeled DC is an Eagle hitch, foot clutch tractor while the others are older. Let's see what others have to say. Not a bad looking DC in the photo.
dctom
05-03-2005 16:50:23
 Re: DC CASE in reply to PaulL, 05-03-2005 15:15:29
you are right, the eagle hitch tractors used the heavy DC wheels the others used SC pressed steel or cast wheels tom
JDB
05-04-2005 06:40:41
 Re: DC CASE in reply to dctom, 05-03-2005 16:50:23
My wide front DC is a 52 with eagle hitch. Would the build card say what rims it left the factory on? Would be nice to have a little more weight up front. Are they the same rims as the narrow front? Seems like they were 3 bolt and my wide front is 5 bolt if I remember right.
Glenn F.
05-04-2005 04:57:40
Are the hubs the same? Glenn F.
PaulL
05-04-2005 06:41:56
 Re: DC CASE in reply to Glenn F., 05-04-2005 04:57:40
No. I'm not where I can compare and don't have a parts book handy but if I remember correctly, the wf's with cast wheels use the same hub as the narrow front. I think that's right. Never have actually tried to interchange them.
DKase
05-04-2005 12:30:18
 Re: DC CASE in reply to PaulL, 05-04-2005 06:41:56
My adjustable wide front has hubs that accept both the 3 and 5 bolt wheels. The 3 bolt hubs from the narrow front will not fit without a lot of bearing and race changing. Spindles are lighter on the adjustable wide front.
