310G crawler fan belt
d hilbert
05-03-2005 10:18:51
The crawler guys don't want to talk to me, so I'll try you case guys. I'm looking at changing the fan belt on my 310G dozer, just looking it over it looks like I need to tear off half the frontend to get at it. Any tips or tricks would be appreciated.
Thanks, Dan
Ed in Maine
05-06-2005 05:23:48
 Re: 310G crawler fan belt in reply to d hilbert, 05-03-2005 10:18:51
Sounds like a good solution. I think I will be going with a twist lock too until I have a reason to tear the radiator out and replace with a real belt. Thanks,
Ed
Jim V.
05-04-2005 03:46:45
I used the twistlock belt on a Allis HD10. I had the same problem, having to tear half the front end off. The belt worked fine.
jstpa
05-03-2005 16:01:40
d hilbert, I used twist lock belt that I bought from mcmaster-carr on a lathe that was going to have to come apart to replace a belt, it worked great and saved me a pile of work. After I put it on a guy saw it and said he uses it on couple of his tractors, so I bought some for my sc, havent gotten that tractor done yet, but its worth a try. If you go to the mcmaster-carr website, look under power transmission, then click on v-belts, then click on twist lock to see the stuff. hope this helps, jstpa
Tom b allen
05-03-2005 12:25:03
I have same problem would like to hear if you found a solution.Thanks
