Another weight question
Darrell Marks
05-02-2005 21:32:54
I just was looking through a spec book for Case tractors, and it said the weight for a DC is 7,000 lbs. Is that right? Earlier I had asked for the weight on an SC and the reply was about 4200 lbs. It doesn't look like there is that much iron in the old girl. Don't think I'm an idiot, but I bleed green and this is a new experience for me.
Walt Davies
05-03-2005 10:56:12
 Re: Another weight question in reply to Darrell Marks, 05-02-2005 21:32:54
My case LA says in the manual that it weighs in at 6599 but at the tractor pulls it weighs in at just under 9000 with a 300 lb driver (not me) You need to remember that the weights in the books are stripped models with no water in the tires or fuel in the tank. Sometimes it may even mean dry weight that no oil or gear oil or water in the system. The LA holds 15 gallons of cooling water 15 gallons of gear oil and 4 gallons of engine oil pluss 31 gallons of fuel that can add alot to the weight of a tractor. Case tractor as the guy said are made from cast steal and lots of it. Walt
Ruben Perez Pandolfi
05-03-2005 09:18:20
 Sale Tractor Case Antique in reply to Darrell Marks, 05-02-2005 21:32:54
Vendo Tractor Antiguo CASE Aprox 1950 ubicado en Chile.Sudamerica.
Si Uds me pueden ayudar a contactar algun interesado,les estaria muy agradecido
Les puedo enviar fotos a los interesados.
Muchas Gracias
Ruben Perez
Joe Blahitka
05-04-2005 21:04:59
 Re: Sale Tractor Case Antique in reply to Ruben Perez Pandolfi, 05-03-2005 09:18:20
I think this guy is selling a 1950 Case (approximate year) in Chile South America and he has pictures if you are interested in buying. A little far for me to drive to from Canada!
case poor in pa
05-04-2005 17:12:50
huh?? whud he say??
caseman-d
05-04-2005 20:46:23
 Re: Sale Tractor Case Antique in reply to case poor in pa, 05-04-2005 17:12:50
Well I got Case and 1950. Heck if has to do with Case it has to be good, right!
caseman-d
Texas Denny
05-03-2005 09:06:21
Darrell, when the University of Nebraska tested this tractor, they said the weight was 4750#. When they tested it for pull, Case added ballast (water in Tires and weights) which brought the test weight up to 7010#. So what does a tractor weigh. It all depends!
jal-SD
05-03-2005 07:37:55
Don't let looks fool you, those old DC's & SC's are made out of good HEAVY cast. My Brother-in-law has had a DC under a farmhand loader for years & abused the %#!! out of it for all that time, never a problem with the block showing any signs of stress. I think the engineer who designed that block & rear end system must have been getting a kick-back from the foundary, or the foundary was owned by his father-in-law & he wanted to send some business that way. The castings are very thick, I'd guess that a DC's oil pan weighs at least 150#. It takes two good men to hold it (and a boy to work the bolts) when you take one off or put it back on. (My $0.02 worth. jal-SD)
dctom
05-03-2005 06:56:57
shipping weight on a DC is around 5200# give or take a couple 100
